| Message |
this is my daily driver, 1993 NA. The alignment analysis said the car was "lowered," from which I assume some spring sag after 100,000 miles. Camber was the same on both sides (-1.9 if I recall correctly) so if it is sag, it is equal on both sides. I was asking mostly to try to determine, without taking the whole front end apart, whether it was sag, which i could correct with the camber kit, or bushing failure, whihc would require new bushings or arms.
